HD Channels direct input? | SatelliteGuys.US
sportman13
352
4
I am getting all the new HD channels on D When I punch in the channel number it still comes up with the SD channel and not the HD version. When I use the up down channel buttons it will go to the correct HD channel and display it! How do I correct this so I can direct input the channel number and the HD one will come up???
I have the H20-100 can not get it to direct input the channel number in HD Do I have to install the new fix, or will Directv do it?
Soon you will get an update sent to your receiver, it will happen over night and there is nothing you need to do to get it :)
Jimbo
My temporary workaround is to bring up the miniguide with the blue button and input the channel # there, hit select and it goes to HD channel
Bill
TBS HD lacking?
NHL HD Channels in Guide
