HD Channels in guide | SatelliteGuys.US
briansanders007
295
I have a new H10 box. I hooked it up last weekend and got hd programing fine. However, I can't see any of the hd programs in the guide now. The only ones that show up are the east\west feeds of the networks which I don't get anyway. If I don't sign up for the hd package do they not show up in the guide? Other programs I do not have are in the guide. They were working when I first plugged in the box. I just noticed yesterday. I checked and all three sat's have good signal (phase III).
Make sure you are not using a Custom guide list. If that is OK, just unplug the H10 for a few minutes. After you plug it back in, it will rebuild the channel guide. I have had to reboot my H10 more than any other D* receiver I've owned! :)
Chances are you took the firmware upgrade - it resets your dish configuration so it thinks you only have a round dish.. go back to dish setup and tell it you have the triple lnb dish.
jim
Emergency Help needed
DirecTV poised to take on TiVo
