HD Channels only? | SatelliteGuys.US
HD Channels only?
whitenerj
37
5
Texas
Ok I'm missing a feature that I had on the channel guide of my 622 which showed only the HD channels. Is there any way to show only HD channels without having to create a favorites list and add them manually? I noticed you can show HD and SD channels with HD having priority but I only want the HD channels. Also I'm assuming if I have to do this manually that any new HD channels that come out will have to be adding to my favorites as they appear right?
922 does not have a HD only listing. Need to to a favorites. Yes, any new channels need to be added.
Nope, not quite right. Just goto Menu>Settings>Guide Display and set HD Channels Only
Nope this doesn't work, it still shows the SD channels too just gives HD a priority. I managed to make a favorites list with only HD manually.
622 died and can't upgrade
3D content ?
