HD DVR and Wireless | SatelliteGuys.US
HD DVR and Wireless
dmaffeo
5
Are there any recommendations for connecting my new HD DVR to my Wireless network for on Demand and other features?
Thanks!
You will need a wireless ethernet bridge or wireless gaming adapter (USB wireless adapters will not work). You will need to set it up for your network with a computer before connecting it to the DVR. Other possibilities are an ethernet cable connection or a powerline network adapter (Directv sells these at $50 for a pair; one connects to your router and the other to your DVR).
I don't think I would say powerline is better, but it is cheaper. I have a wireless bridge connected to one of my HD/DVRs and it connects to my wireless router. My other units connect directly thru ethernet cables to the router (best option).
The bridge is better than a gaming adapter (in my opinion) in that it can connect to a switch/router at the remote point and then to the wireless router. This way I can add even more device (such as a laptop, xbox, etc.)
Agreed! I actually prefer the extra cost of router/switche and fishing CAT6 to needed walls.
whats up yall im a tech out of pa and i bought the wireless net adapters from dtv and all it does is tweaks ( ?:"><) my internet .. i tried the wireless bridge that the 360 is on and nothing.. when i disconnect the adapter and reset every thing all is fine .. i even updated my wi router to a "N" but still the same
Direct TV install on house is not an option!
DirecTV Prepaid/PREPAGO
