HD DVR Issue | SatelliteGuys.US
HD DVR Issue
itherrkr
33
Nampa, ID
If I access the mix channel in NFL ST and then go to any channel, the info bar freezes on the screen and I cannot change channels. The thing just fries, basically. I have to unplug and reboot to get it back to normal. Anybody else have this issue? Last week and this week.
I havent had that exact problem but mine on some sports recordings wont fast forward or rewind after ive recorded it and even rebooting wont help. (HR20-700) From what ive read sounds like a faulty hard drive. Im calling DTV in the morn to get a replacement and ive only had it for a couple weks.
They will go thru all the normal checks, reboot ect. and then send a tech out at a time you and them can work with.
Then IF the tech can't fix it , they will then send you out a replacement.
Just letting you know not to expect it in a few days, is all.
Jimbo
New installation, adding an H20 receiver
PREMIUM SERVICE DISCONNECT FEE - Charge
