- I'm eyeballing itWhat model of HD-DVR are you talking about?
- An HR20-700
When you say you did this yourself, do you mean you did the complete install yourself?
- Yep, I connected the dish and receiver, I used the same cord (RG-6) that I used with my old dish.
How many lines did you run to the DVR?
- If I know what you're asking, I have 1 cord connected to the dish and then 2 connected to the Satellite-in part of the receiver.
Do you have the BBC's installed?
-Yes, both of them
Do you have a multiswitch installed, and if so, what type?
- I think so, it's a yellow device that has 1 input outlet and 2 outputs. They call that a hybrid splitter converter.
Do you have splitters anywhere in the line?
- Not sure what that is, but I have a hybrid splitter convertor, maybe the same thing.
Are you sure that you've gotten a signal from the sat when installing the dish?
- I've gotten no signal. Expect at one point where the receiver recognized satellite 110, but then when I went to signal strength I still got 0
How are you aligning the dish (with a meter or using the receiver)?
And finally, did you run guided setup and select the correct dish type?
Understood, but if the receiver doesn't recognize the dish then it doesn't matter how allinged the dish is.
- I'm eyeballing it
Limited time offer
