HD FTA Help | SatelliteGuys.US
HD FTA Help
Spike
616
59
Suburbs of Milwaukee
Alright. I am slowly getting to where I want to be. I need some help though. How are you guys getting the HD channels off of the satellite and onto your TV's without the purchase of expensive HD FTA receivers.
I'm hoping for a component cable hook up from my computer. Can such a thing be done? And if so, what equipment do I need?
There's also the excellent VLC Videolan program (http://www.videolan.org/vlc/), which is great for streaming HD media on a PC.
As Shawn said, DVI is perfect for getting HD out of a PC to a HD monitor. If your monitor has HDMI instead, an adaptor cable is available for $50-$75 that has HDMI on one end and DVI on the other.
Viewsat Extreme Info?
76 CM Good to go?
