HD hook-up & D* | SatelliteGuys.US
HD hook-up & D*
Pandian
4
I have good OTA hd via 811 finally.
I installed:
1. Radio-shack V-75 XR... via DC Blocker DSV 47...to
2. diplexor DSV 97 to join one output from DP34 ... to 811.
3. another diplexor DSV 97 to respective inputs.
Will I loose signal strength if I split OTA for more receivers?
Is DC Blocker DSV 47 a signal booster - it is from a multiswitch DSV 95 - that I am not using right now (from my Dierctv days)?
Can I use a multiswitch DSV 95 to split signals for my other receivers?
I have a new unused DP1 - how can I use it?
Help me.
Thank you.
Some! I split my OTA signal from a pre-amp to 4 different tuners and I'm still over-powered on a couple of channels. Only way to know is to try it. However, if your OTA digital signal strength is currently at 70 or below, you will probably experience dropouts after you split your signal.
501 Problems
Buying the correct DVI cable?
