I was looking through the forum and happened across the term "HD lite" I hadn't heard it before, so I googled it
What the heck is up with this???
Are any Dish HD Chan's currently broadcasting HD lite? I thought the channels used to look better but I thought maybe I was just getting accustom to the HD.
Before you say, "If you can't tell which channels are in HD Lite, you must not be able to see the difference". Every different HD chan/program seems to have a slightly different picture quality, it would be hard if not impossible to where the picture degradation was coming from.
Anyway, whats the latest on this?
Thanks,
Brad
Thanks,
Brad
