Any know exactly the bill E* introduce to allow satillite providers to sell Network HD to locals where they stations are years away from going HiDef?
I don't know were you're located but in Central Ohio all locals are now supplying "HD" when In "HD", but you'll be a old person berfor " E " or "D" will uplink locals in "HD". so for the next 3-8 yr's you'll have to live with " OTA ",so Voom must have had it right from the Start, " Free "OTA Ant", " ask D or E if they'll give you a Free " OTA ant " for their "HD" Box. ?gutter said:If the government wants to encourage digitals and HD, they are going to have to put pressure on the locals to go HD. That bill would have encouraged HD and put pressure on the locals to upgrade their digital analog to HD compatability.
kelljc said:I don't know were you're located but in Central Ohio all locals are now supplying "HD" when In "HD", but you'll be a old person berfor " E " or "D" will uplink locals in "HD". so for the next 3-8 yr's you'll have to live with " OTA ",so Voom must have had it right from the Start, " Free "OTA Ant", " ask D or E if they'll give you a Free " OTA ant " for their "HD" Box. ?
ROLLZROYCE said:"live with OTA", that's easy for you to say, sucks for us that can't receive even ONE channel OTA such as myself. Looks like I will have cable for locals for 3-8 years
P.S. If D* isn't uplinking locals in HD for 3-8 years then how are they going to back up their "1500" HD channels by the end of the year thing?
kelljc said:I don't know if that's what "D" stated I thought they stated in the next 3 yr's,
if you're correct then great for you. but I don't think so. Let's see 3 Sat's @ 36tps per, == 108 Hd bandwidth, = 324 seem's short to me but I don't know.
ps. Has D or E added Universal HD or EncoreHd as of this date?. and what
new channels have they added in the past 4 years.
JoeSp said:I believe that you are using current satellites up and MPEG2 for your math. You must add in the Spaceway satellites going up in the next three months and recalculate for MPEG4 being used. This will increase the number of channels by a factor of 2.5 to 3 per MPEG2. I don't really know the correct numbers but D* will definately have plenty of room. As for HD LIL D* has already announced the top 12 markets up by summer. After the FCC gives approval to E* for their purchase of Rainbow 1 they will have simular capacity. This fall will be exciting for alot of us HD viewers!![]()
theres another satellite thats going up this year its called directtv 8 its a better replacement for directtv 2 i beleve has both ka and dbs transponders so most likely this sat will allow for national hd on the ka band .especally since spaceway 1 will use spot beams on ka the other ka transponders will be for spotbeam . fyi space way 2 will be at 99 degrees and spaceway 1 will be at 101Lobstah said:This was posted on another HD forum I hang out on:
"The most concerning part of that plan for most of us is that the first bird is due to carry ONLY Local HD channels. According to their releases, they plan no more national HD channels until 2007! There is NO WAY that can be accurate. If it is, people will be flipping by then.
Also, all our hopes for increased picture quality given these satellites just went out the window. It appears as if all the extra bandwidth they have is going to, again, more channels.
If a service came along that provide the key channels I'm interested in and did so with a minimum of compression, I'd drop DirecTV in a heartbeat and move there. I am so tired of seeing CNN anchors look great when they don't move and then becoming fuzzy when they so much as twitch. It's quite annoying when you become aware of it. Hopefully MPEG-4 will address some of this but I have my doubts. "
Lob
that new channels well first d does have universal hd plus they were adding national network hd feeds ny/la . granted alot of the country cant see them but they had the superbowl in hd did e no did voom nope d atleast has a plan . but ill be the first to say i want voom to work jus tfor the simple fact its keeps d* and e* working to add hdkelljc said:.
beast37799 said:that new channels well first d does have universal hd plus they were adding national network hd feeds ny/la . granted alot of the country cant see them but they had the superbowl in hd did e no did voom nope d atleast has a plan . but ill be the first to say i want voom to work jus tfor the simple fact its keeps d* and e* working to add hd
im enjoying hdtv too sat and ota especally with the upcomming noreaster tomorrow here on the jersey shore near the real point pleasentSeattleVoomer1 said:Dead or not still enjoying HDTV under clear (rain promised!) Seattle skies, Gill
Nothing specific like that.Jamey K said:Any know exactly the bill E* introduce to allow satillite providers to sell Network HD to locals where they stations are years away from going HiDef?
chevyN8 said:Nothing specific like that.
Is it possible to have D* broadcast local HD channels that don't exist? AFAIK they can't. The local channels still have a while before they really have to broadcast HD at full power, if they will ever have to. My local broadcaster tells me the "don't have the money to upgrade" excuse loophole is still working. So they won't upgrade until someone tells them they have absolutely no choice (with no valid excuses). So, D* will probably start adding HD LiL, but to locations that have OTA HDTV--not helping those that really need it. If they could offer network HD feeds to those of us that can't get OTA HD, the local broadcast networks would at least have some incentive do HD stuff.
Yes, I didn't say that, but I do know that. It's not much different that how I can't recieve analog locals via a huge antenna w/preamp, but D* and E* couldn't provide distant networks because I needed a wavier. Local broadcasters never sign any waviers in my area. Since E* lit-up our LiL's I've seen lots and lots of superdishes, the only other choice was cable. Ya, the law really didn't make local broadcasters do anything.rkr0923 said:It's NOT D* that refuses to give anyone localHD.........it's the way Congress has wrote the law....D* would LOVE to supply anyone and everyone with ALL the HD but their hands are tied
Limited time offer
