Be careful if you are looking for a box to buy on ebay. As i understand it, Comcast boxes can not be purchased, only leased through them. So if you are buying one, it might be stolen.I have an HD ready tv and i looked on ebay for some hd receivers here are some of the results:
samsung sir-t150
samsung ts360
MOTOROLA DCT6412
TOSHIBA DST3100
any suggestions?? if it is a dvr slash hd receiver, will the dvr work with basic cable??
Thanks alot
Jason
They're pretty hard to find though. A couple of things though, the menus don't display on composite only on HDMI and component.
Does it have that limitation if you set it to 480i? I have the sir-t451 and it can show the menu on composite if the output is set to 480i.
I tried using the 811 in QAM mode to scan my local OKC Cox cable, but it didn't find any transponders. Wonder if I did something wrong?
This new Samsung HD tuner has a QAM/ATSC tuner:
http://www.circuitcity.com/ssm/Sams...64855/catOid/-15607/rpem/ccd/productDetail.do
Limited time offer
