HD OTA Suggestion. | SatelliteGuys.US
HD OTA Suggestion.
Buzzdar
735
USA
Ok based on my zip code (62896) what would The great people of this forum recommend for me as a good HD OTA Antenna. I am looking to buy something in a store i would prefer not to have to buy it online if at all possible.
Thanks for your time.
All the Digital XMTRs appear to be UHF band, 19 - 40 something miles. I recommend you go with an 8-bay bowtie antenna, Winegard HD8800 or Channel Master 4228.
What city's local stations are you aiming for?
EDIT: You best options are ABC from HARRISBURG, IL , NBC from PADUCAH, KY and MNT from PADUCAH, KY. The channel master 4228 is a good antenna.
No FOX or CBS :(
Advice on Cleveland Locals
OTA and Satellite
