HD Ready TV and VIP 622 Question | SatelliteGuys.US
tangreg
4
I have a Sony Wega 16X9 HD Ready TV. I just got DIsh Netowrk HD package, and the HD programming is great. However, my locals do not come in HD. Do I need to get an antenna to connect to the back of the VIP 622? Any help on this would be greatly appreciated.
If you subscribe to locals and you are lucky enough for Dish to have your Locals in HD on satellite then you just need the appropriate Dish or Dish's.
If you do NOT live in a market that Dish has your Locals in HD, then you will need a OTA antenna to connect to your VIP622. I would suggest you go to a website (Antennweb.org) this site will ask for your address and then tell you which OTA signals you should be able to receive, their azimuth and the type of antenna that you need to receive them.
John
Thanks for the info. I live in the Austin area, and I don't believe they have locals in HD via satellite, so I will go the OTA atenna route. Thanks for the quick post. I really appreciate it, as I have not gotten any decent advice from anyone.
Does Dish broadcast the SD locals for Austin? If they do and you put up an antenna and get your OTA locals in HD, you might want to subscribe to the SD locals, so that you get the guide data for those local HD channels. Otherwise you can only set up manual timers on the 622.
Right, but they already have SD locals right? So see the post above for why you might want to subscribe to them.
Upgrading to 622 questions
61.5
