HD Receiver audio boost? | SatelliteGuys.US
jnelson
7
Las Vegas
Is there a way to boost the audio coming out of a DTV receiver? If you push the volume controls on the remote it wants to adjust your TV volume.
Any ideas?
Thanks!:up
no, that is how it works. the audio is output high impedence low level, and your tv/surround system changes it to low impedence high level for the speakers. either turn your TV up, or if your tv volume is not enough get a good surround system. HD shows always seem to have lower audio levels than non-HD versions.
An outboard audio pre-amp or mixer.
The output level is line level and not variable like you may have seen on some televisions (and probably some cable/converter boxes).
Thanks for the answers guys. This is not your normal DTV installation. This system is installed in a rack in a 10 rack server room and is providing HD and SD signals for encode demos. Someone had asked if we could boost the audio signal coming out of the DTV box but I didn't think so without a separate audio amplifier. I currently have it running into an SDI embedder in order to route it into our Matrix switcher.
Cheers
Cheers
Tha answer to the question is the same though.
There is NO way to turn UP the recvr(s) as there is no way to turn up any other kind of input to the TV(s).
Directv2pc help!
Changing service on the D* Website
