HD Receiver, no HD TV. | SatelliteGuys.US
mikefran13
Hello
I have an HD receiver because a HD tv is being delivered to me however for now I am using a regular TV. When I hook up my HD receiver all I get is that it is searching for a signal. I have a DVR receiver that works fine. What can I do
Receiver ID 0231 6463 8654
Serial # A03BC6HE220626
DTV PN: H20-100
Dish Info:
Model FW9
S/N: F00F61603868C01
mikefran13 said:
Hello
DTV PN: H20-100
Dish Info:
Model FW9
What type of dish do you have it hooked up too ? What is a FW9 ?, I am unfarmiliar with that model.
HD required at least a 3 LNB dish.
Jimbo
HD receiver can work with any dish even in the settings menu it gives you options to select any dish.
One possible problem is a wrong multiswitch. In fact if you have a wrong multiswitch it is not only gonna be "searching for satellite" but it will permanently damage your HD receiver and you will need to replace it. I've seen that happen.
NFL Replay is HD. Where is it D*?
