HD receivers with analog tv's | SatelliteGuys.US
Bluztrvler
53
South Carolina
Anyone know if the HD receivers like the Pansat 9200HD downconvert the HD feeds to the analog outputs, or is the HD content passed only to the HD outputs (HDMI etc.)? I am considering adding one of these to my system.
Thanks.
Anyone know if the HD receivers like the Pansat 9200HD downconvert the HD feeds to the analog outputs, or is the HD content passed only to the HD outputs (HDMI etc.)? I am considering adding one of these to my system. Thanks.
I've watched downconverted HD with that box via the S input on an old CRT set. The only problem is aspect ratio, the people look squished, etc.
Iceburg uses his cs8100/8000 to down convert and I dont recall it being bad
actually the 8000 is hooked up via the HDMI cable but as brent noted, when recording it doesnt look bad. Gives a nice SD recorded version of a HD broadcast
What good are all-port power-passing splitters?
Dual Standard LNBF
