HD system dish size for Mexico | SatelliteGuys.US
moisheh
2
Canada
We are planning on getting an HD system for Mexico. We are in Northern Mexico 250 miles South of Tucson. Presently use a 30 inch dish for SD. Will the normal slimline dish work this far south? Where can I find a larger dish that will accept the 5 LNB ?
Moisheh
The sats are in orbit over the equator. Therefore, you're closer to the sats than most of the US.
Moisheh
This is not nearly as far south as southern Texas, you should have No trouble at all getting signal with the Slimline set up.
Before I call, I need advice...
Playon for your HR receivers 1/2 price
