HD Tivo ,Anyway to output 2 singles at 1 time? | SatelliteGuys.US
LOBO2999
823
Cumming, GA
I got an HDMI hook up to my bedroom tv but have another Tv ( not HD ) across the hall and have the cables run White red & yellow & they are coming from the back of the HD tivo , but when I try to get a single on the Tv in the other bedroom I get nothing unless I set the HD Tivo to 480i and then I lose my single on my bedroom Tv , but I get it back if I set it to 480P,720P or 10801i, any work around for this?
Thanks!
Sorry, you are out of luck, the non-HD outputs do not have any signal when you are using either component or HDMI. The new DirecTV DVR the HR20 has all the outputs active so you can make this work, but not on the HD TiVO.
Help with DVR Remote
Directv Plus DVR (R15) lights - turn them off?
