HD TV w/PVR 721 and 811 receivers | SatelliteGuys.US
royann
2
I have a Mitsubishi 73" HD TV. I have a PVR 721 attached. There is no way I would ever give up the PVR functionality even for HD. I have been waiting patiently for the PVR 921, but am getting impatient. I heard that existing customers could get the 811 for $199. At this rate I might buy one. Can I put both the PVR 721 and 811 on the same TV? and how would I do this? I also have 2 other receivers in the house.
You would need to run another line from the dish to feed the 811, then hook the component inputs to the 811. Done. leave the 721 hooked up as is.
Depending on the age of the mit's you may need to get an adapter cable to access the HDTV inputs.
Motorola 6208 cable DVR has rocky start
problem with 3900 upgrade reciever
