Is there any way to ad GUI to my HDD 200 decoder? It's from circa 2001 and all standard def is in 4:3 aspect. Is it possable to install the software or flash a eeprom ?
Cheers,
Cheers,
Skyvision sells used HDD 200 that have been "flashed" with the current GUI upgrade, so it must be possible.
Previously Owned Motorola HDD200 Decoder
Just watch the SD using your 4dtv composite or s-video output and stretch the pic using your tv. The hdd-200 has terrible picture quality unless you are actually viewing HD. Mine can't even "center" a SD picture properly let alone up-convert it decent.
can you post some pics of the sd channels through the hd-200? then a hd channel
thanks
thats not that bad, i was expecting worse.
what kind of flatscreen would do sd well?
im not so sure rca is an off brand
they have a 1080p 40" HDTV at walmart for 600 bux
but im gonna wait till black friday
if i can snag a sony, toshiba or samsung 32" or 37" 1080p set for $600 il get it
if not il get an insginia at bestbuy, acording to the web, its just a rebranded sharp panel made with lg parts
I had a insignia 32 inch LCD. It is now in the garbage after working for just 2 years.![]()
should of gave it to me, coulda had it fixed
The parts would have cost more than it's worth.
capacitors, ic's, resistors are about 15 cents a pop. Now if it was the back light or the panel, you get cashy
Limited time offer
