HDMI Connection | SatelliteGuys.US
HDMI Connection
jrv331
109
6
NE Ohio
Im getting a 722 installed in the morning and need some info on the connection. I want to use a HDMI cable but have read that you need to turn things off and on in a certain order or audio/video may have problems. Is this really a concern? Secondly, my HDMI tv port does not have any audio in plugs. Does this mean I dont need seperate audio cables? I currently have my cable box hooked up via red, blue and green cables but figured I might as well try the step up to see if HDMI is any better.
John
the hdmi cable includes both video and audio so that one cable is all you need.
additional audio cables are not required.
Don't worry about the sequence in which you turn things on, either. Get a Harmony 880 and it will control everything you have in your HT.
Any hopes for HD Channels on Sat 119 and 110, from 129
119W Echostar7 footprint
