I tried to attach the pdf file so others couldWell 1st its not all on Dish's end! Sometimes its on the TV's end also and not everyone is haveing issues. Either way I think Dish is addressing the issue with the folks that are having the issue.
I have the Dish 211 hooked up to a Sony KV-36HS510 (4x3 aspect ratio). I recently bought an HDMI to DVI cable to try to get the optimum picture. For some reason, when I set the resolution on the receiver above 480P (720P and 1080i) it vertically compresses the image on every station, HD and standard. When I try to adjust the picture (stretch, partial zoom, etc.) I can only change the HD settings (no SD) even on SD stations. Also the sound doesn't work through the HDMI/DVI. Are these common issues? Is there something wrong with the receiver?
I must be in the big minority on this. I have a 211 and 622. Both using HDMI. I have not had 1 single problem with the outputs on either receiver.
That was me until last week...
Is there a way to slip this issue into a Charlie Chat or one of those forums?
Limited time offer
