Hdmi splitter | SatelliteGuys.US
Hdmi splitter
traxxs
70
want to take the ps3 hdmi connection and send the signal either to my dell 2407 used for gaming or the 50in crt used for movie watching. is there a switcher or something that has 1 hdmi in and 2 hdmi outputs.
I am not trying to display at the same time ,just use 1 or the other when im gaming or watching a dvd
Only for $17.64 each when QTY 50+ purchased - 2X1 Manual HDMI Switch - Push Button Type | Manual HDMI Switch
You can use it for 2 sources and one output or 2 outputs and one source. I wont allow display on both at same time. Its just a very basic switch.
I've tried to use their cable splitters and there are issues with those. They are not compatible with all devices. The switch though works with everything I've tried.
I use one of these also, works just fine...
DVR (through Comcast) vs DVD Recorder
Reprogramming a SA Explorer 8300 SD
