HDTV Antenna | SatelliteGuys.US
HDTV Antenna
nick2003
6
Hey everybody, Im looking to buy a good hdtv antenna, The farthest station looks like about 27 miles and im in a basement will i be able to use one there or will i need to bring it upstairs? I really want an indoor antenna i dont want to get on the roof. Will any of these at bestbuy work? http://www.bestbuy.com/site/olspage.jsp?id=cat08084&type=category
I want to get one around here somewhere not really into ording online. Thanks
You may have a problem in a basement. Your probably surrounded by cement walls and steel support beams. The best bet is a outdoor antenna. If any of your digital locals are VHF forget the basement antenna. Try this link for local information.
http://antennaweb.org/aw/Address.aspx
If in doubt try the antenna. Best Buy is great as far as returns.
Thanks cpdretired , Which outdoor antenna would you recommend for zip code 49017 if its not to much trouble and where would i find one of those and the cable to hook it up? Thanks
Defective Quad LNB?
Who to Go With??
