HDTV approved | SatelliteGuys.US
HDTV approved
RidgeRunner
174
32
Raymond, Maine, United States
So I'm about to buy some parts to add a second KU dish. I've been shopping for a switch and a LNBF and a switch. I've noticed that some LNBFs say "HDTV approved" I don't know what makes it approved but I can imagine there would be a difference, but some of the switches say the same thing. So what makes a switch special for HDTV?
Your receiver and your TV need to be HD, that's it. The labeling is designed to confuse and trick people who haven't studied before they go shopping.
Cheers, Steve
On the GEOSATpro LNBFs we use the term HD ready or HD compatible to answer the endless question, "Does this receive digital channels".
No difference, just answers questions...
If there are two products on the shelf and mine says "HDTV", I'll make a sale and the other guy won't. :)
If you need general guidance on switches, see the FAQ:
http://www.satelliteguys.us/threads/134124-Switch-setups-simplified
I don't know your goals nor intentions, but the Standard PLL LNBF from SatellliteAV, and the Ecoda 22khz switch both come highly recommended.
Assuming they fit your needs, of course.
Well Anole my intentions are to setup a fixed 75cm dish, I'm not 100% sure but I'm leaning towards 30 degrees. I have everything I need except a LNBF and a switch. I will also be needing a geostat micro had which appears to be highly recommend. Although I do not need the receiver right away but I do want to be HDTV capable eventually.
I kinda figured what you guys were posting on HDTV, but I thought I would double check.
There is an authorized reseller selling the MicroHD receiver on Ebay for $108 with FREE shipping. I've dealt with him multiple times, and had good service every time. http://www.ebay.com/itm/microHD-GEO...US_Satellite_TV_Receivers&hash=item3f1a591c69
kinda like TV antennas that say "HDTV ready" when your 30 year old antenna works just fine
bought a nos outdoor antenna (1969) on ebay awhile back packaging said it got Color TV........ tooo funny
using some lnb's here from the 90s........... don't tell them their getting HD stuff
Someone said that the new generation Geostat MicroHD will be on sale in a month. Is it true? Any ideal about the cost of this new divice?
Questions about dish i scored
Anybody else lose 12180 on AMC-21
