HDTV question ? ( Help ) | SatelliteGuys.US
yel-mel
11
I am new to HDTV. I just got a used Samsung hcm4216w from a friend that moved and couldnt take. From what I have read the tv is HDTV " ready ". What do I need from Directv to receive high def broadcasts ?
Samsung specs state :1080i HDTV monitor performance with add-on HDTV tuner.....not sure what that means...
Thanks so much :)
Thanks so much :)
If the TV has component, DVI or HDMI inputs, all you need is a HD tuner from D*. You don't really need the add in box from the televisions' manufacturer. :) Enjoy!
free previews
TiVo Delivers Improved Quarterly Results
