HDTV through lcd projector | SatelliteGuys.US
Not open for further replies.
captain slagle
OK, I asked this at audioholics and didnt get a clear answer, so ill give it a try here. I have an epson powerlite 7350 that i want to hook up to my HDTV box. I have HDTV and the projector is capable of HDTV.
The cable box has:
Y Pb Pr
DVI-D
S-Video
IEEE 1394
And standard rca video
outputs
The projector has:
Y Cb Cr BNC
RGBHV BNC
VGA
S-Video
and standard rca video
inputs
What is the cheapest, easiest way to hook up HDTV from the cable box to the projector? I have hooked up the Component YPbPr video to the YCbCr input and regular shows come in fine but HDTV just goes blank. Somebody said that the YCbCr input is digital, can you get a DVI-D adapter? Im open to anything, any help is greatly appreciated.
If it just goes blank you might want to double check your res settings. The box might be putting out 1080i while the projector can only handle 720p or vise versa.
Sony makes style pitch to women for flat TV
Help! New Aquos
