HDTV with PC | SatelliteGuys.US
HDTV with PC
Neutron
Founding Supporter
18,716
1,124
Texas
I know my video card will do component in. Is it possible to connect a second monitor to my video card (it allows two), and connect our Directv HD-DVR box to it and push the tuner output to the second monitor?
We may be consolidating TVs to make room and was just curious. I have Vista Business now and I would have to upgrade to Ultimate for it to work of course.
That may be true, in fact, I bet it is.
I guess I would need to look into a tuner card then.
The only (relatively cheap) way to get content from your Directv receiver to a computer is via s-video/rca composite. I think there are one or two PC cards that can take in component, but you are talking big bucks.
For s-video/composite, I recommend haugauge pvr-250/350 cards...it has a builtin mpeg encoder so it doesn't burden your CPU...however if you have a real fast CPU, you can get away with a capture card that doesn't have the mpeg encoder.
For locals, get a HDTV tuner card also.... recording doesn't use much CPU, as the stream is already in MPEG format....it's just writing to the hard drive.
