hello need help | SatelliteGuys.US
hello need help
BIG_DUDE_4002
4
hi i have fortec lifetime ultra i just bot a new 35 inch/89 cm 35 Ku Band dish i need help to set up my reciver dont know what to put i am trying to get t5 network on the lnb it says satsound and u cant turn the lnb becuse the holder it is on screws and on the lnb it seys up so dont know how to set it up plz someone help me
i live in canada ottawa ontario and that is what it seys on the lnb sticker p1705-asth single output digital ku-lnbf
input frequency: 117-12.22 ghz
output frequency: 850-1450 mhz
atlanta dth.inc.
Hello and welcome to the SatelliteGuys.US FTA Forum :wave
First thing you will have to do is set up for the correct LNB.
If its a standard LNBF the L.O. should be set at 10750
If its a Universal LNBF then set it for Universal 1 9750/10600
If you give us your zip code we will give you all the angles to point your dish : O
Let us know what it says on your LNBF, maybe there are some numbers there that will help.......
OK Its a Standard KU LNBF....the L.O. should be 10750
Latitude 43° 40.000'N Longitude 79° 24.000'W
Sat Name Sat Lng Az(t) Az(m) El Skew
Intelsat 901 18.0W 110.6 122.4 11.7 -42.6
Intelsat 603 20.0W 112.2 124.0 13.1 -42.0
NSS 7 22.0W 113.8 125.6 14.5 -41.4
Intelsat 905 24.5W 115.9 127.7 16.2 -40.6
Intelsat 907 27.5W 118.4 130.2 18.2 -39.5
Hispasat 1C/1D 30.0W 120.6 132.4 19.9 -38.5
Intelsat 801 31.5W 122.0 133.8 20.9 -37.9
Intelsat 903 34.5W 124.7 136.5 22.8 -36.5
AMC 12 & Telstar 11 37.5W 127.6 139.4 24.7 -35.0
NSS 806 40.5W 130.6 142.4 26.5 -33.3
PAS 6B/3R 43.0W 133.1 144.9 27.9 -31.9
PAS 1R 45.0W 135.2 147.0 29.0 -30.6
Intelsat 705 50.0W 140.8 152.6 31.7 -27.2
Intelsat 707 53.0W 144.3 156.1 33.1 -25.0
Intelsat 805 55.5W 147.3 159.1 34.2 -23.0
PAS 9 58.0W 150.4 162.2 35.2 -20.9
Amazonas 61.0W 154.3 166.1 36.3 -18.3
EchoStar 3 & Rainbow 1 61.5W 154.9 166.7 36.5 -17.8
Estrela do Sul 1 63.0W 156.9 168.7 37.0 -16.5
Brasilsat B2 65.0W 159.6 171.4 37.6 -14.6
Brasilsat B1 70.0W 166.5 178.3 38.8 -9.7
Nahuel 1 & AMC 6 72.0W 169.3 181.2 39.1 -7.7
DirecTV 5 72.5W 170.1 181.9 39.2 -7.2
SBS 6 74.0W 172.2 184.0 39.4 -5.6
AMC 5 79.0W 179.4 191.2 39.6 -0.4
Nimiq 2 82.0W 183.8 195.6 39.6 2.7
AMC 9 83.0W 185.2 197.0 39.5 3.8
Brasilsat B3 84.0W 186.6 198.5 39.4 4.8
AMC 16 85.0W 188.1 199.9 39.3 5.8
AMC 3 87.0W 190.9 202.7 39.1 7.9
Intelsat Americas 8 89.0W 193.8 205.6 38.7 9.9
Galaxy 11/Nimiq1 91.0W 196.6 208.4 38.3 11.9
Brasilsat B4 92.0W 197.9 209.7 38.1 12.9
Telstar 6 93.0W 199.3 211.1 37.8 13.8
Galaxy 3C 95.0W 202.0 213.8 37.2 15.7
Intelsat Americas 5 97.0W 204.7 216.5 36.6 17.6
Galaxy 4R 99.0W 207.3 219.1 35.9 19.4
AMC 4 101.0W 209.8 221.6 35.2 21.1
AMC 1 103.0W 212.3 224.1 34.3 22.8
AMC 15 105.0W 214.8 226.6 33.5 24.4
Anik F1 107.3W 217.5 229.3 32.4 26.1
DirecTV 6 & EchoStar 6/8 110.0W 220.6 232.4 31.1 28.1
Anik F2 111.1W 221.8 233.6 30.5 28.8
Solidaridad 2 113.0W 223.9 235.7 29.5 30.1
SatMex 5 116.8W 227.9 239.7 27.4 32.5
EchoStar 7 & DirecTV 7S 119.0W 230.2 242.0 26.1 33.7
EchoStar 9/Intelsat Americas 13 121.0W 232.1 243.9 24.9 34.8
Galaxy 10R 123.0W 234.1 245.9 23.6 35.8
Galaxy 12 125.0W 235.9 247.7 22.4 36.8
Galaxy 13/Horizons 1 127.0W 237.8 249.6 21.1 37.7
Intelsat Americas 7 129.0W 239.6 251.4 19.8 38.6
AMC 11 131.0W 241.3 253.1 18.4 39.4
Galaxy 1R 133.0W 243.0 254.8 17.1 40.1
AMC 10 135.0W 244.7 256.5 15.8 40.8
AMC 7 137.0W 246.3 258.1 14.4 41.5
AMC 8 139.0W 247.9 259.8 13.0 42.1
EchoStar 1/2 148.0W 254.9 266.7 6.7 44.3
Satellite Finder is (c) Copyright 2004, P. Lutus
C-Band With Coolsat 4000 Pro HELP!!!!
Watching Hispasat with Dish Network 500 dish?
