Help!! 5 LNB dish assembly instructions! | SatelliteGuys.US
hjenssen
14
Is there anyplace on the web I can go to get assembly instructions and installation instructions for Directv slim line 5 lnb dish?
I've searched this forum and can't seem to find it.
I purchased the dish on E-Bay and it didn't come with any instructions.
Herb
Thanks cforrest,
Is it possible to set this up without a meter?
I don't have one.
Herb
P.S. I have a smaller 3 LNB dish installed presently
I am no help answering that one, hopefully someone that did their own install can give you some tips and pointers. Best of luck with the install of the dish.
You can do it with onscreen signal meter it is slower and may not be as accurate. Why not just get the free upgrade from D*
I installed one using just the signal strength screen. Start with satellite 101, then try 103c to fine tune it. Also make sure 119 looks good, the others should fall into place.
Remember, plumb pole & very small movements.
Anyone ever quit DTV, then come back with a good deal?
HR20 Multiple Output
