Help 72.5 Locals - R10 DVR | SatelliteGuys.US
dh0765
2
Hi, I have 3 R10 DVRs in my home. One has both coax lines running to it, and the other two just have one coax running to them. I installed my second dish and set it to the 72.5 bird. I installed the WB6x8 switch and got it all set up. On the R10 with two coax lines, I detected everything just fine and have my 72.5 locals on it. The other two R10's with only one line will not detect the 72.5 bird. They all three have the same software versions. My question is, "Why wont the other two R10's detect the 72.5 bird?" When I run the auto detect, they won't recognize anything but the 101. Please help!
Did you check to make sure the single line units ARE set to "one coax only" on the initial setup? You need to rerun initial setup to do this, THEN you run auto-detect to find the 72.5 sat.
Yes, they are set up for one coax only, and then I ran the auto-detect and they just won't find the 72.5. They only find the 101.
My first impressions of D* after switching from E*
3 LNB oval dish and Las Vegas locals
