HELP! can't get 110 | SatelliteGuys.US
HELP! can't get 110
avsfan33
27
I had a problem getting even transponders on 129.
I moved the dish, now I get all 119 and 129, but only evens on 110. any ideas on what the problem is?
With a dish 1000 you can only peak 119 signal and make sure 110 comes in as high as you can get it and do you have a dish pro plus twin and one dp dual and if so then then the line from the dual should be going to the in port on the dp twin
when you do the check switch... where is it saying 119 and 129 are located... port 1, 2, or 3?
if it's 1, and 2, then your dish is not lined up correctly, elevation a little high, and little too far to the right
Yea I got the same issue with my dish 1000 I just installed . great sig. on 119 on the #2 spot on switch page no 110 or 129. orig setting 234 34 130, moved skew to 126 got 129 on the #1 spot on switch at 49 signal /still +100 on 119 at second spot. but no 110. moved back to orig. and back to just 119. What am i doing wrong got 110 and 119 fine with my old dtv olip. dish . Any suggestions pulled my hair out for 2 hours don't know what I'm doing wrong. or which way to go be tuesday before i can fool with it some more just watching the 119 stations.:eek: :eek: :eek:
pick the dish from 129 port ,,, make sure u maximise the signal through the port ,, when done ,,tight ur dish and make sure the port from is having a better signal dont know what ur using to peak ur dish as far as satelitte meter ,,,make sure also the dish mast is leveled ,, both sides...goodluck
TBS, Baseball & HD?
Chicago HD Locals, (Now macroblocking)
