Help--Directv HD Receiver and HR 15 | SatelliteGuys.US
on2wheels
4
I have a stand alone RCA (Directv) DCC210 HD receiver with no DVR. Rather than upgrading to an all new HR20 to get DVR, is there a way I can use the standard HR15 to record and then play through the HD set? Or somehow, use the HR15 with the HD receiver and TV set? I don't care whether the DVR records HD or not and I don't mind some switching back and forth between equipment or sources. I would just like to have the DVR and be able play it back through the same TV set even if it is standard TV. I don't get much HD anyway! Is it is possible? I now have the HD receiver connected directly to the HD TV by component and the audio through an audio receiver.
Or would I have to do a complete install of both receivers and then somehow switch them back and forth?
That said, I could use the HR15 on another tv in another room, but then how could I then playback on the HD widescreen?
(fairly electronically challanged.)
on2wheels
(also posted on our HD forum)
Replace your HD receiver with the HR20-700 for $199 through D* and get the AT9 installed free so you can get the future MPEG4 broadcasts,800-531-5000 ask about upgrade offers.
OTA tuner to be enabled on Nov.. 1st?
Space broadcasts to be in high definition
