Help from First Strike FS1-SE users | SatelliteGuys.US
  • Thread starter Thread starter hobie16
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
hobie16
104
2
USA (Full time RV'er
I recently purchased a FS1-SE Sat Meter for setting up my RV antenna. The instruction manual leaves a lot to be desired!!
I have gone to lygnSat to get the correct set up info for transponders on 61.5 and 72.7 but don't understand the correct use for the 22khz function. I am using an EA .2 antenna with the dual LNB head. Do I need to have the 22khz signal on and use the Lnb selection function buttons of the keyboard to switch between LNB's or should it be off ? I seem to be able to read one LNB not the other.
Also should I get a "locked" indication for these sats?
Apprecialte any guidence you can give me.
Moving to a Condo...
