help help | SatelliteGuys.US
help help
eddieblue
9
south mississippi
i need a little help a friend gave me a cband dish and an old general inst 450i box but no manuel the dish has 4 cables running out that was cut off at about 10 feet 2 of the cables are regular coiax the cable from the motor has 5 wires red white yellow green brown the red and white are a little larger than the others the 4th cabe has three wires red white black i am trying to find cable to splice into these so far no luck does anyone know where these wires connect to the box im famaliar with ku i have a coolsat 6100 and a sv box can i slave the coolsat to the 450i i believe its analog or is there some way i can hook the coolsat to the motor and get it to work the dish any info helpul thanks
Pansat 9200HD bugs and older firmware??
Did I fry my LNB?
