Help hooking up Terk BMS-48 | SatelliteGuys.US
DrummerSmith1
8
Help hooking up Terk BMS-58
Good morning all,
Well, it is Sunday morning and I am finally hooking up my new multiswitch, I know that a lot of you have already used this switch with the new phase 3 dish.
Do I need to hook the 58 to the outputs on the back of the dish or do I need to hook it directly to the lnb's. I know that there is an internal multiswitch inside the dish, I am just wondering if I need to bypass this.
Good morning again and thanks for your help
$100 DirecTivo Rebate
DirecTV Plans for 119
