Help !!!! I have lost some HD channels !!!! | SatelliteGuys.US
mikfro
7
memphis, Tennessee
Help !!! I have lost some not all HD Channels could this be a B-band converter problem or a dish alignment problem, the attached file are my transponder readings, on a second question I have a 6x8 zinwell multiswitch it has on the input ports 13 volt and 18 volt ports whih lnb goes to which port?
View attachment transponders.txt
The lines from the dish (4) connect to the 13v and 18v inputs on the WB68. It doesn't matter which order. I assume you have the AU9 dish with the 5LNB.
What DVR/receiver do you have?
Try swapping around the BBCs.
To eliminate the WB68 as being the problem bypass it.
Your 99 and 103 sats look abit low, could use a tweak, but that should bot be causing your issues as you would still have picture at the levels you have.
LNB Help
Harmony H659 Reset
