Help me identify this dish | SatelliteGuys.US
dishdude
SatelliteGuys God
28,692
55,622
Phoenix, AZ
This is an eastern arc dish, I believe a 1000.2. Can anyone confirm? Also, can I replace the LNB and convert it to a western arc?
1000.2 Eastern Arc which is missing 2 bolts from the skew plate. Yes, you can convert it but you need a western Arc LNB
Reactions: dishdude
So if I have this correct, the 1000.2 EA and WA dishes are identical other then the LNB?
Is it true that the 1000.4 EA and WA dishes are different and cannot be converted between EA and WA?
is 1000.2 the one being used on new installs?
1000.2 EA and WA dishes are the same.
1000.4 dishes can be used on either arc depending on the LNB.
Yes, 1000.2 dishes are used on new installs.
Reactions: dishdude
So does one of them get better signal then, as it's larger reflector?
No, actually, on a .4 Eastern Arc, I can never get all 3 sats dialed in properly. The only thing a larger reflector does is improve rain fade but in this case, it's only slightly larger
Reactions: dishdude
Dish Brings Netflix to the Hopper Duo DVR
Hopper 3 audio issue: low volume
