GEOSATpro - Help need reset my Geosatpro receiver! | SatelliteGuys.US
GEOSATpro Help need reset my Geosatpro receiver!
N5XZS
4,819
2,840
Albuquerque, NM, USA
I try rebooting my receiver but no luck. I think my video went to 50 Hz, so can you help my by step to step by going blind remote controling to get back to 480i 60 Hz and work my way up.:coco
Thanks....
Base video setting on MicroHD is 480i 60Hz normally as default, I believe. At least on the small plug-in video cord. You might want to try that if you still have the cord.
Try this: Hit 'Menu', then "down arrow" twice (this might vary depending where you last were in the menu), then "right arrow"once, then 'List-OK" then 'Right arrow' and see what happens... Each "right arrow' press changes to another resolution, provided you actually are on the Resolution screen. Once you get it where you want it, hit 'Exit' 3 times in a row.
It did not work on my HP computer monitor, so I ordered an new Micro HD receiver for the time being it's should arrived by end of this month.:) As for older version I will keep as a back up.
AMIKO How does the Big2Small app work?
