I added a little dish to my 10ft.B.U.D. An idea that came from Fat air. After seeing a pic he had as his avatar a long time ago. The little dish is a Directv Slimline dish with a Dish network fss lnbf and circular lnbf that was used for 105 locals. My ? is what setting should I use in the Openbox for the lnbf. Right now I'm using 11250 and it works,is in I can scan most the tp's on one polarity, but not all. Example would be Galaxy 19 at 97.0°W, if looking at lyngsat the last 4 tp's don't scan in. With this setting all tp's scan in with higher freq. most are off by 508, some around 1508. 10750 works, but not all tp's scan in and are the same Horizontally as Vertically.
