HELP-Suddenly NO SIGNAL | SatelliteGuys.US
hmjs
26
United States
Suddenly no signal on my 722K. Started switch test and a came up "TV 2 in use" ??? Ran test and "Reception Verified" DP Twin with a notice that said "have fewer satelites than previously. Checked signal screen and no signal on either 119 or 110. Is my 722 dead?
And 129 is fine? I'd be suspicious that your LNB/DPP switch has failed, rather than the receiver.
Yes go out and check all of your connections, before you assume a receiver.
You need a 1000.2 to get most HD channels anyhow, so I think it's time to get a tech out and to get your dish upgraded.
Will check connections again, never know! The reason I suspect the receiver is because the test shows I have signal and
?when I went to start test I got a message that tv2 was in use.
Well guys, it was a bad LNB. Thought sure it was the receiver since LNB's don't fail that often.
Thanks for the input.
OK, I'm impressed...
1/2 Off HBO/Cinemax six months.
