help wiring my superjack EZ-6000 | SatelliteGuys.US
humaxstryker
2
hello
the wires on my positioner snapped
plz help me reconnect them
there are 4 wires RED BLUE WHITE and BLACK
with 4 slots
MOTOR +
MOTOR -
SENSOR -
SENSOR +
and if i conect them wrongly its no problem right?? cause of the circiut protection and stuff ??
thanks
I remember i had this problem!
I guessed many times and had no problems (nothing broke).
RED AND BLACK ARE MOTOR +/-
(try red + and black -) if dish goes east when pressing west then the wires need to be flipped.
guess on the other two, if it doesn't work switch it!
Red Motor +
Black Motor -
White Sensor -
Blue Sensor +
It Worked Just Fine......thanks Alot
The Weird Thing Is That The 4 Wires Are The Same Gauge!!!
