Help with 622 installation question..... | SatelliteGuys.US
hzhao
280
Finally, I got my 622 box and activated last night. The whole process is another long story and I will share with all later.
Here is my question:
Does 622 support analog OTA channels? I was unable to add one analog channel that I was modulated and inserted in my analog antenna. I have no problem with all the previous receivers (811,921,942). All I need to do is manual add a OTA analog channel. Seems 622 only allow me to scan/manual add digital channel.....
Am I miss something or doing things wrong?
Thanks in advance.
Thanks.
I had some CCTV channels that I have inserted in the OTA antenna feed..... I guess that I just need find other way to do that now......
hzhao said:
Thanks.
Try using a simple splitter at the OTA input to the 622 and feed the OTA and CCTV signals to your TV's OTA/cable tuner if it has those, then tune the CCTV signals that way. If your TV is only a monitor, depending on what channel the CCTV signals are on you might be able to use an old VCR or similar as the tuner...
Need som expert advice. Thank you
Too big a dish?
