Help with 72.5 locals | SatelliteGuys.US
paul3500hd
15
This has probably been asked before but I am new here and was wondering if a Super Dish from Dish Network would work to get the 101 and 72.5 (my locals ) sat in one dish? I have the 4x4 switch for Direct Tv.
Still learning here
Welcome to SatGuys Paul. Unfortantly the answer to your question is no. The 72.5 bird is to far away from the 101 bird for one dish to pick them up.
A Superdish wouldn't work anyways because the Dish Network LNB's on there are stacked frequencies whereas the DirecTv ones are not (also the DirecTV switches wont work with a SD)
Just use a 2nd 18" dish
Ok Then...
Can anyone tell me where I can get the elavation and azmuth for the 72.5 sat using my zip code?
Every program I find only gives me angles for 101sat...Thanks
ESPN MLB Game tonight
Please list what satellite's are on and Where
