you shouldent have much trouble .i live here in corner brook newfoundland on the east coast ihave 97 and 101 on an old star choice 39" dish works perfectly.:upThanks. This is my old lnb.
The feed horn on your old LNB feed horn maybe to large to work with your dish.Thanks. This is my old lnb.
just wondering how you made out,bro?Thanks Iceberg. I had a good feeling about it, but better check with pros before do the work.
Limited time offer
