Im living in Fairfax county Va-going HD this friday with d@ network...I went and bought the small 15-2160 UHF antenna from rat shack...my towers are all 19 miles away in Wash DC and all lie at 89 degrees on UHF channels...Im giong to do attic setup and Ive seen several posts on this site saying that the people in my area are using an amp with this antenna (a few without)to get a boost on an average signal-now do I put this power inject up in that attic, close to the antenna-or do I hook it up from the wall outlet to the tv...?
Ive got antenna-transformer-amp-then power pack-then coax to wall-short coax and thus to tv OR
antenna transformer amp-coa
say 75')-wall-short coax-power pack-tv
Only 1 tv in this set up-oh and Ive seen in the manual that no splitters between power pack and tv-does a X2 female F connector count as a splitter-as I will need one if I put the power pack up in the attic, its TV out line has a male end and my coax lead up there is male also...
Hell I might not even need the amp...
Sorry for the noob questions-I have searched all over the boards for this answer-have found others though
All this and my sox might win before I get the HD on friday
