help with Captiveworks | SatelliteGuys.US
gamara
7
help
heres where i am at.cw600s,30inch dish,motor,lnb invacom quad polar,4-1diseqc2.0.lnb in (not out?)tv ant in,out to tv.when im scanning my reception could be as high as 90/quality 50 and no channels come up not one i tried it on many satellites.any help?
broke off review :)
I assume you have it hooked to the dish in (its on the left hand side on the back of the box) and not the RF in (on the right right above the rf out)
yes left side of box(LNB in)let me start with my LNB i have one cable coming from each of the 4 outputs L C L C to my 4-1 diseqc to back of box (LBN in)out from tv/vcr to tv.nothing on the LBN loop out???anyway be kind,thanks
do this
-turn off the unit with switch on back and remove all cables from switch
-hook up to one of the "L" ports (no switch involved) and then turn unit back on to start aiming
You would only need one of the "c" ports and one of the "L" ports when done :)
What's your zip? Then we can give you the angles you need. I would try to aim at your true south satellite without the motor to get the hang of where it should be. Then add the motor later :)
Code:
                  Peotone, IL 60468
     Latitude 41° 20.166'N Longitude 87° 47.382'W
              Sat Name Sat Lng Az(t) Az(m)   El  Skew
            Telstar 12   15.0W 101.6 104.8  4.2 -47.4
          Intelsat 901   18.0W 103.7 106.9  6.4 -46.9
                 NSS 7   22.0W 106.5 109.7  9.3 -46.0
          Intelsat 905   24.5W 108.4 111.6 11.2 -45.4
          Intelsat 907   27.5W 110.7 113.9 13.4 -44.6
         Hispasat 1C/D   30.0W 112.6 115.8 15.2 -43.9
          Intelsat 801   31.5W 113.8 117.0 16.3 -43.4
          Intelsat 903   34.5W 116.2 119.4 18.4 -42.3
           AMC 12/T 11   37.5W 118.7 121.9 20.5 -41.2
               NSS 806   40.5W 121.4 124.6 22.6 -39.9
             Pas 3R/6B   43.0W 123.6 126.8 24.3 -38.7
                Pas 1R   45.0W 125.5 128.7 25.6 -37.7
          Intelsat 705   50.0W 130.4 133.6 28.8 -34.9
          Intelsat 707   53.0W 133.6 136.8 30.6 -33.0
          Intelsat 805   55.5W 136.3 139.5 32.0 -31.3
                 Pas 9   58.0W 139.1 142.3 33.4 -29.5
              Amazonas   61.0W 142.6 145.8 35.0 -27.1
            EchoStar 3   61.5W 143.2 146.4 35.2 -26.7
             Rainbow 1   61.5W 143.2 146.4 35.2 -26.7
      Estrela do Sul 1   63.0W 145.0 148.2 35.9 -25.5
          Brasilsat B2   65.0W 147.5 150.7 36.9 -23.8
          Brasilsat B1   70.0W 154.1 157.3 38.9 -19.2
              Nahuel 1   71.8W 156.5 159.7 39.5 -17.4
             DirecTV 1   72.5W 157.5 160.7 39.7 -16.7
                 AMC 6   72.0W 156.8 160.0 39.6 -17.2
                 SBS 6   74.0W 159.6 162.8 40.2 -15.2
            Echostar 4   77.0W 163.9 167.1 41.0 -12.0
                 AMC 5   79.0W 166.8 170.0 41.4  -9.9
               Nimiq 2   82.0W 171.3 174.5 41.9  -6.5
                 AMC-9   83.0W 172.8 176.0 42.0  -5.4
          Brasilsat B3   84.0W 174.3 177.5 42.1  -4.3
              AMC 2/16   85.0W 175.8 179.0 42.1  -3.2
                 AMC 3   87.0W 178.8 182.0 42.2  -0.9
                  IA-8   89.0W 181.8 185.0 42.2   1.4
             Galaxy 11   91.0W 184.9 188.1 42.1   3.6
             Nimiq 1/3   91.0W 184.9 188.1 42.1   3.6
          Brasilsat B4   92.0W 186.4 189.6 42.0   4.8
             Telstar 6   93.0W 187.9 191.1 41.9   5.9
             Galaxy 3C   95.0W 190.8 194.0 41.7   8.1
             Telstar 5   97.0W 193.8 197.0 41.3  10.3
             Galaxy 4R   99.0W 196.7 199.9 40.9  12.5
       DirecTV 1R/4S/8  101.0W 199.6 202.8 40.3  14.6
                 AMC 4  101.0W 199.6 202.8 40.3  14.6
            Spaceway 1  102.0W 201.0 204.2 40.1  15.6
                 AMC 1  103.0W 202.4 205.6 39.8  16.6
                AMC 15  105.0W 205.1 208.3 39.1  18.6
           Anik F1/F1R  107.3W 208.2 211.4 38.2  20.8
           DirecTV 6/5  109.5W 211.1 214.3 37.3  22.8
            EchoStar 6  110.0W 211.7 214.9 37.1  23.3
            EchoStar 8  110.0W 211.7 214.9 37.1  23.3
               Anik F2  111.1W 213.1 216.3 36.6  24.2
         Solidaridad 2  113.0W 215.5 218.7 35.7  25.8
              SatMex 5  116.8W 220.0 223.2 33.8  28.9
             DirecTV 5  119.0W 222.5 225.7 32.6  30.5
            EchoStar 7  119.0W 222.5 225.7 32.6  30.5
 EchoStar 9/Telstar 13  121.0W 224.7 227.9 31.5  31.9
            Galaxy 10R  123.0W 226.9 230.1 30.3  33.2
             Galaxy 12  125.0W 229.0 232.2 29.1  34.5
         Galaxy 13/H 1  127.0W 231.0 234.2 27.9  35.7
  Telstar 7/Echostar 5  129.0W 233.0 236.2 26.6  36.8
                AMC 11  131.0W 234.9 238.1 25.3  37.9
             Galaxy 1R  133.0W 236.7 240.0 24.0  38.9
                AMC 10  135.0W 238.6 241.8 22.6  39.8
                 AMC 7  137.0W 240.3 243.5 21.3  40.7
                 AMC 8  139.0W 242.0 245.2 19.9  41.5
            EchoStar 1  148.0W 249.3 252.5 13.4  44.6
            EchoStar 2  148.0W 249.3 252.5 13.4  44.6
   Satellite Finder is (c) Copyright 2004, P. Lutus
i believe i have the correct location,my gps is very close to where you told me(but when entered,my box seems to set location back to stock setup)every time i go to sat set up its back on stock location not mine, and where i enter is erased.as for true south from what i could find is 8deg.west of magnetic south. ???
I don't have that receiver, but you probably have to store or save your lat. and long. before leaving the setup screen. Again, not sure since I don't have that box.
is it possible to have 90 st 25 qu pointing at lets say echostar1/2 and not actually be on that satallite.is this why i have no pictue?if i can manually move my motor to the highest strenght,am i not where i should be?my location is entered!why no channels? as for captiveworks user manual either i suck or it does.
lost with set up of hh90 motor
Confused with Elevation and Declination
