Hi everyone,
I have recently bought my first setup after reading in the forums, and finally received the following from Sadoun:
Invacom .3db Universal LNBF - SNH031
Fortec Star 100CM Dish
Fortec Star Lifetime Ultra Receiver
SM3D12 HH Motor
It is mounted on a plumb 3" galvanized pole beside my house now. I live in Dyersburg Tennessee zip code 38024. I zeroed the HH motor, mounted the satellite according to instructions, and made sure the LNB satellite and motor/mount were all in a straight line. I directed it to 181 degrees on the compass as best I could <there is not much in the way of points of reference on the mounting bracket for this seemingly quite important operation>.
The part that has got me is what angles do I put on the satellite and HH Motor. I feebly attempted to calculate it from the instructions, and used Sadoun's website for lat/lon information, and did the calculation for the motor/sattellite angles as directed, but I am not getting any signal, not even close. My satellite seems to be pointing more downwards than all the directv satellites around, but I do not know if this is from the design of the dish or if it is pointed completely wrong. Also, in the instruction manual it said to point the dish to IA-5 for initial setup, but I seem to vaguely remember someone saying in the forums that you pointed initially to your southernmost satellite.
Alas, I am not surfing the airwaves yet, and am quite disappointed with myself for not being able to decipher the instructions. If someone could point me <pun intended> in the right direction, it would be greatly appreciated and make me hug you muchly
Thanks in advance for any help!
SM3D12 HH Motor
