I plan to set up using a CK-1 LNB. I installed the circular filter, though doubt that it will be of any use - never know. But my question is, the end cap on the LNB doesn't fit tight at all
. I feel it will come loose over a short period of time, so wondered if wrapping some teflon sealing tape around the sleeve portion of it will help. Also, there are 8 holes around the outer edge of the face of the cap. Won't this be an invitation for water to enter the LNB? Should I place a sheet of cellophane over the end and then put the cap in place? The CK-2 is almost identical if that will help. I could post a photo if needed.
Thanks, Bill
Thanks, Bill
