Help with setup of 942 | SatelliteGuys.US
DishDave
898
9
Here's my situation. Need help with the correct setup
Have a 942 Hooked up to my big screen on TV 1 Via HDMI. I live by myself so i only want to watch the samething any tv set. So i want my 942 to backfeed muy other 2 tv sets. On my old 522 i just used the coaxial input on TV1 and ran it in single mode. But now i donot have that option no coax on TV1. What is the best way to configure my receiver for my situation ?
who_the said:
Just run coax out of TV 2 and enable "Shared View" in System Setup. This will mirror TV 1's content onto TV 2.
Related question: Is the coax output of TV-2 much different than the composite (other than the obvious of longer runs & intergration with cable system). In other words, will the signal be the same / worse / better ?
Just wondering if coax would be a better way to hook up my dvd recorder than composite.
The composite output gives you a better picture. As for your other TV's you would need to hook up your tv2 output to a splitter and the other tv's need to be on the channel you set your tv2 modulator to ie ch cable 73.
New 721 weirdness?
winegard ota amplified can i add another amplifier
